Re: Wheel Weight Bolts
Posted by John A. on February 15, 2013 at 13:59:51 from (64.128.16.238):
In Reply to: Re: Wheel Weight Bolts posted by IAtractorKid on February 14, 2013 at 23:18:43:
IA Kid, I encourage you, Before! you get too deep into this project to get those wheels dished out, and set relatively wide!!
2nd IMO 3 wts alone is not enough. Since you have enough for 3/side and they are splits use them on an Inboard position. get 6 solids for 3 on each of the Outboard positions. Use the solid 3 ft all threads so more can be added later.
Similar but not the same!
A relative has a 4230 with 330 lbs inboard and 335 outboard ? side and with a full bucket of soil the back end is still 200 to 300 lbs light / side,(IMO) handles the same with 1500lb hay rolls too.
There is NO SUCH Thing as TOO much Wt to keep a loader tractor Stable!
Later,
John A.
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
