Re: 966 Farmall no hydrolics
Posted by Allan In NE on February 16, 2013 at 03:15:05 from (148.66.88.254):
In Reply to: 966 Farmall no hydrolics posted by 966 on February 15, 2013 at 14:51:44:
My feed tractor does that almost every morning when the temps are low. I let it sit there and warm up and it will eventually wakes up.
I suspect that the hydraulic oil needs to be changed; probably a high percentage of water.
Allan
