Re: Farmall 400 Power Steering?
Posted by D Slater on February 16, 2013 at 07:04:33 from (184.15.14.56):
In Reply to: Farmall 400 Power Steering? posted by Tinks on February 15, 2013 at 17:45:16:
Can't say I would recommend it but a fellow had a M with the same pump that only supplied the power steering and used it for years. It was one of the behlen steering units with the built in reservoir housing. Steered like a dream.
If you want to try you need some kind of fluid reservoir and at least a cross over relief valve between pressure and suction lines.
Must be a puller if you want to remove those parts, most also go to manual steering to save a little more weight and the power lost to turn the pump.
