Re: Serial Number on a Farmall A
Posted by BJP on November 07, 2000 at 07:31:22 from (128.146.213.70):
In Reply to: Serial Number on a Farmall A posted by Dennis on November 07, 2000 at 05:42:43:
The S/N should be found on the left hand side of the seat assembly, close to where it is bolted to the frame, at the bottom. Most likely it has been painted over and may be hard to find. Good Luck.
Post A Followup
: Re: Re: Serial Number on a Farmall A
