Re: B-414 1850 loader
Posted by jimb2 on February 16, 2013 at 08:06:59 from (99.241.76.141):
In Reply to: B-414 1850 loader posted by De Castro on February 14, 2013 at 16:54:53:
Hi, I believe the IH 1800 series of loaders were designed for the IH 74 series of tractors ie 574,674 etc. You do not want to put a loader on a tractor that is to heavy for the tractor as it will wreck the front end. Look for an IH 1500 series loader or OEM equivalent. We had 434 with 1501 loader and 384 with 1550 loader. Either would fit B414 but head lights must be moved.
JimB
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
