Re: Choke
Posted by Bob M on November 07, 2000 at 09:27:52 from (192.232.120.194):
In Reply to: Choke posted by planzman on November 07, 2000 at 09:04:19:
Having to choke the motor to keep it running means it's getting too LITTLE gas. Your symtoms sound like a blocked air vent in the fuel tank filler cap. Try loosening the cap next time the tractor starts to die out. If you get an inrush of air and the motor picks up, you found the problem. Also check for junk in the bottom of the tank that is covering the fuel outlet. And make sure the fuel sediment bowl and inlet screen on the carburetor are clean.
Good luck!
Post A Followup
: Re: Re: Choke
