Re: Super M brake pedal shaft removal
Posted by D Slater on February 17, 2013 at 04:59:02 from (184.15.14.56):
In Reply to: Super M brake pedal shaft removal posted by Dalrymple on February 16, 2013 at 19:49:06:
If the exposed parts of the shaft is okay the inside probably got some rust sometime. Unless the top cover is being removed to see whats going on. Get a bigger hammer, but that may batter the shaft end unless care is taken.
