Re: baling with hydrostatic drive
Posted by The tractor vet on February 18, 2013 at 07:48:25 from (75.19.115.148):
In Reply to: baling with hydrostatic drive posted by Redhendrix on February 17, 2013 at 19:38:45:
The big this is the size of the tractor , Figure on the weight of the baler then the weight of the wagon EMPTY and it out weighs the tractor then ya stack on a load . NOW on table top ground not somuch and issue but then ya add in a grade and things can turn ugly fast . For us over here with 99% of the fields with humps and bumps in them it is not such a good idea. As we found out one day with my S/H and a New Holland 68 baler and one 18 foot wagon with around that many bales on . The Super h has decent tires fair power and had four sets of 150 lb weights on with no fluid in the tires . while pulling up the one hill everything was going good till almost the top the ground was a little damp from the rain four days before and the S/H lost traction and started to paw a bit so i added a little left brake so the right wheel would dig a little and all of a sudden both tires broke loose and forward movement stopped and we started down the hill backwards . Eugene and Dusty jumped for it and how i kept every thing straight i have no idea , only slid back down the hill about a hundred feet or so but felt like a mile . That was the last day we used the S/H for that . When we moved up to the 336 J D baler the 706 got put on it and even with a 9000 lb tractor and a 2/3rds. load on the same wagon in the same field the 706 at times will paw , the 806 weighs in at close to 14000 and it has been shoved down a hill with close to a full load . It does not matter what your doing with a piece of equipment you can never let your guard down . Just like plowing , there is nothing more relaxing then plowing in the spring , love plowing in the evening in the spring vary relaxing BUT you still have to be on guard as i can not count the times i have hooked into something and had the tractor stand up even with a full rack or ft. weights on the nose . Or get shoved sideways on the headlands while planting corn or mowing hay , the latter is a every year occurrence on the one field. and that is with a heavy tractor with good tires and just pulling a 1219 J D haybine . Just remember the TAIL CAN WAG THE DOG.
