Re: Farmall230 Exhaust Manifold
Posted by Les Repair on November 07, 2000 at 16:46:37 from (206.28.174.185):
In Reply to: Farmall230 Exhaust Manifold posted by Ron P on November 07, 2000 at 09:31:58:
Your dealer probably sold you one for a Super C. These have a longer neck than a 230. I'm not sure if you can get the correct from CNH, and I think most of the after market ones are for the older tractors. You might check the salvage yards for a good used one. 240 Farmall is the same.
Post A Followup
: Re: Re: Farmall230 Exhaust Manifold
