Posted by Jonski on February 18, 2013 at 09:32:01 from (66.116.62.178):
Are the hydraulic touch control units the same from C to Super C?
Have SC tractor and a spare C touch control.
The touch control on the SC is very slow in lifting a 6' snow plow both hot & cold. Fluid & hydraulic screen are OK. Lift position with plow and tractor not runnning plow immediately descends to ground. Hydraulic draw bar will lift small truck off ground so believe hydraulic pump is OK. Believe the touch control should be able to lift 2000 lbs.
Would rebuild touch control on SC but just too cold for this fine work now. Can I check some prone areas like relief valve, broken spring etc??
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
