The pickup on a 14T does not turn as fast as the later bailers. The 3.5mph speeds sounds about as fast as that pickup can handle (3rd gear on a 3020). 2.5 mph was a common bailing speed for our 14T (2nd gear). Your tractor's low range sounds ideal for baling.
With flat fields and only mild hills your tractor should be fine pulling the bailer and wagon. If you push it, a 14T bailer will take in enough hay to pull down a 34 HP tractor engine. I'd be more concerned about the tractor's engine overheating than the transmission. Watch the gauges and slow down if the tractor gets too warm.
My only concern would be at transport speeds. Slow down if you try to pull a full wagon behind the bailer at road speeds. The total weight could push the tractor and get squirrelly if you need to stop in a hurry.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
