Re: M Gear Oil
Posted by Janicholson on February 18, 2013 at 12:42:56 from (199.17.6.95):
In Reply to: Re: M Gear Oil posted by sflem849 on February 18, 2013 at 09:50:36:
Would 3 gallons cover enough of the bottom to lube the trans shafts and bearings in the input shaft? It seems like a small amount to be sure of essential lube. Jim
