Re: Farmall 140 Will Not Crank
Posted by old on February 18, 2013 at 12:43:50 from (209.86.226.19):
In Reply to: Farmall 140 Will Not Crank posted by Kyrock on February 18, 2013 at 11:46:09:
Those pull type starter switches are known to get bad and sometimes need cleaned or replaced. I would remove to 2 screw holding it to the starter and clean up the part on the starter and the inside of the switch with emery cloth and see if that fixes your problem
