Posted by D Slater on February 18, 2013 at 15:36:33 from (184.15.14.56):
In Reply to: Re: 300 shift lever posted by greg potts on February 18, 2013 at 14:56:36:
H and M won't work. You have the wrong shifter number if its for a regular 300. Number you posted is two piece. Farmall 400 will work. Should find a number near the lower end of the shifter. It will be a different number than whats in the parts book. If your shifter looks like the upper one in the picture or worse it needs work. Other one is close to normal. Sometimes the slot you see in the shifter will be worn 1/4 inch or more wider on some. Welding and some machine work should fix the one you have unless realy junked.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
