I figured that the 8hp Kohler weighs around 75-80 lbs w/ oil. The gearbox that I put in weighs around 40lbs. I'm thinking that the LB weighs around 250lbs. I'm building a frame that will bolt where the gas tank skirts and the grille used to be to help support the load. If it becomes a problem, I can get beefier spindles and bearings later. To help with the 300-500RPM range of the LB I'm going to use a 2:1 belt drive to get the driveshaft RPM up to what the Kohler would have.
I'll take some pictures of the clutch pulley later tonight and link to them on here.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
