Re: Farmall 140 Will Not Crank
Posted by gene bender on February 18, 2013 at 17:04:53 from (67.55.226.151):
In Reply to: Farmall 140 Will Not Crank posted by Kyrock on February 18, 2013 at 11:46:09:
Chances are the starter is licked on the ring gear take the bolts out where it mounts to the bell housing and wiggle it. That should get it loose can happen in cold weather easy.
