Before you loosen the bolts on the starter, try just rocking the wheels with the tractor in high gear. If the starter is locked, it will not move the fan until it the starter pops out. If rocking the wheels does not do it at first then loosen the two starter bolts, do not remove them, just loosen and rock the wheels with it in high gear. You will hear a pop when the solenoid springs back out of engage and the fan will start moving. Tighten the bolts and it will crank then. It was a common problem for the C-113 and C-123 motors and happened so seldom we did not make an attempt to remedy and kept a box end wrench (I think a 5/8") in the tool box for just this problem. You can also check to see if the starter is locked by using the hand crank. If it is locked, you may not be able to turn the engine with the hand crank, but I have been able to unlock a starter a few times with just the crank. It all depends on how hard it is jammed in. Once it locks up, do not pull on the starter rod again until it has been unlocked, you just bind it in harder.
Today's Featured Article - Uncle Cecil's Super A Lives Again - by Mike Purcell. A week or so out of most of my childhood summers was often spent with my Uncle Cecil and Aunt Sissie in the small East Texas town of Maydelle on their 80 acre farm. Some of my fondest memories of these visits are those of learning to drive a tractor at the helm of Uncle Cecil’s 1948 Farmall Super A. Uncle Cecil was the second owner of this wonderful little tractor, but it was almost as though he had adopted an infant. The original owner was a man from Minnesota who bought her from a local dea
... [Read Article]
Latest Ad:
[More Ads]
