With the engine stopped and the governor handle at "idle" does the gov to carb linkage move freely? If not, find and correct whatever is causing it to be stiff.
If the linkage is free, problem is likely carburetor adjustment (too lean at full throttle).
With the engine warmed up and running at full RPM, try pulling the choke out SLOWLY. If you find a choke position that makes the surging go away you've found the problem.
Solution is to open the carb load needle 1/4 turn at a time until the surging disappears. However if after opening the load screw 2 - 3 turns the engine still surges it's time to go inside the carb and clean it out.
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par
... [Read Article]
Latest Ad:
[More Ads]
