Re: B RPM surging - Gene Bender
Posted by old on February 20, 2013 at 08:45:51 from (209.86.226.30):
In Reply to: B RPM surging - Gene Bender posted by Matt E. on February 20, 2013 at 06:58:27:
Almost bet your carb main jet is clogged up and needs cleaned out. If it is like most carbs on the B the main jet is not adjustable so you remove the cover plug and let fuel flow out of it and also stick a small wire in to clear it out
