Re: Follow up-----140 will not crank
Posted by Bob M on February 20, 2013 at 12:37:44 from (74.67.191.60):
In Reply to: Re: Follow up-----140 will not crank posted by uncle henry on February 20, 2013 at 11:31:56:
I wondered why when I purchased my Super H came with a cheap 3/4" combination wrench hanging from the choke rod. Figured it out a day or two later the first time the starter jammed.
Replacing a badly worn ring gear solved the problem. (I tossed the old wrench...)
