Re: 1944 Farmall H coil/external resistor
Posted by wayne in mn on February 20, 2013 at 15:05:00 from (71.8.151.79):
In Reply to: 1944 Farmall H coil/external resistor posted by lane Valley on February 20, 2013 at 14:55:52:
Resistor goes first. However, if you are still 6 volt it is not needed.
Are you changing to 12 volts?
