The best of my research into straight cut bevel gears is that there are only two adjustments. Pinion depth, and backlash. (ring gear depth in the pinion) In all my gear work, I have never seen straight bevel gears with more than about .006" backlash when new. The machining of the differential housing by IH when it was manufactured pretty much guarantees the planar relationship between the two axis of rotation (ring gear and pinion) If it were mine I would set it up to have about .008" backlash and run it. It will make some noise, but it will probably wear in and be less distracting. The only thing that can make the issue be weak and easily damaged is to have the pinion shaft (trans output shaft) either bent, or out of alignment. The intermediate (pilot bearing between shafts, and the front trans bearing all play in the same orchestra toward that alignment. If those are good, set it and run it. Jim
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
