Bearing install
Posted by Bkpigs on February 20, 2013 at 19:22:46 from (24.182.229.14):
When installing a bearing on a shaft that is press fit, do you guys use a punch on the inside race to fit it? I used a rubber mallet as a block and hit it with a hammer. I figured the rubber mallet would spread the force over a wider area and lessen the shock. Now the bearing has a slight click that I didn't notice before. Never had this issue before but this bearing was one of the tightest I can remember. Thanks!
