Re: One more differential question
Posted by pete 23 on February 20, 2013 at 20:05:55 from (74.47.40.242):
In Reply to: One more differential question posted by Zachary Hoyt on February 20, 2013 at 17:47:45:
You won't hurt it. I would suggest making sure the differential does not have over a few thousands run out on back of gear. Some times you have to loosen and retorque the bolts or shift the ring gear to a different position on the differential. Also, I never saw one of them set up with any less that about .010 and most closer to .012 when new in the 4 and 560 tractors. Better loose than tight within reason of course. Flush pinion or slightly protruding pinion, never less than flush into ring gear. Like I said before, they can drive you crazy or you can get lucky. There are humps on both sides of them gears now and they will take a long time to wear off.
