Re: Cub oil pump shaft
Posted by mkirsch on February 21, 2013 at 05:02:46 from (64.80.110.74):
In Reply to: Cub oil pump shaft posted by JDnTN on February 20, 2013 at 19:06:28:
Do you mean the hydraulic pump? Because "oil pump" normally refers to ENGINE oil pump, and the engine oil pump on a cub does not have any o-rings or shafts that I can see in the parts diagram. It drives off the camshaft.
If you are talking about the hydraulic pump, try to find a good used one. Cub parts are pretty common.
