Re: Cub oil pump shaft
Posted by gene bender on February 21, 2013 at 06:26:27 from (67.55.226.151):
In Reply to: Cub oil pump shaft posted by JDnTN on February 20, 2013 at 19:06:28:
I would sand it till all the burs are gone then install the speedy sleeve as any burs will not let the sleeve slide on easy. i did that once on the Cs pump
