Re: crank cam timing on h international
Posted by El Toro on February 22, 2013 at 07:15:50 from (108.3.218.181):
In Reply to: crank cam timing on h international posted by e. Sahr on February 22, 2013 at 04:46:16:
A service manual is very helpful when working on these old tractors. Mesh the single marked tooth on the crankshaft gear between the the two marked teeth on the cam gear. Then mesh the single marked tooth on the camshaft gear between the two marked teeth on the magneto gear. The governor and idler gears do not need to be timed to the engine. Hal
