Re: on/off switch on M
Posted by Bob M on February 22, 2013 at 09:18:32 from (74.67.191.60):
In Reply to: on/off switch on M posted by hayfarmer on February 22, 2013 at 09:11:52:
Yup - different switches are used for distributor and magneto ignition.
A distributor switch has two terminals. Its contacts CLOSE when the switch is pulled out and OPEN when it is pushed in.
Mag switch has a single terminal (the other contact is grounded internally). It grounds the magneto when it is pushed in.
