Re: F20 water in oil
Posted by Bill Lisbon on February 22, 2013 at 16:13:09 from (69.89.162.197):
In Reply to: F20 water in oil posted by Daninsc on February 22, 2013 at 15:53:28:
F-20's used wet sleeves, you could have a pin hole in the sleeve where it has rusted thru. You could check by removing head and fill block with water and watch for any leaking water coming on top of piston. Water could also leak into the oil from the bottom of the sleeve if the O-ring seal is bad.
