Re: 706 international gas
Posted by Janicholson on February 22, 2013 at 17:10:35 from (74.60.94.18):
In Reply to: 706 international gas posted by scott kel66 on February 22, 2013 at 16:17:24:
As Pete indicates. Probably a hydraulic lock (fluid in the combustion chamber, could be gasoline, or coolant, or water down the muffler.
In all cases find out what it is before cranking it with the plugs in. If a piece of metal from ? gets on top of a piston, it will destroy the engine if cranked (especially if pull started. Were it mine I would look in each cylinder with a bore scope if there is no fluid in the cylinders. I also would make sure to assess the type of liquid in the chamber when getting it to turn over. Insight there is important. If it is frozen, water. (probably the best thing to find) you may need to heat that cylinder with a propane torch till it melts out.
Bent rods broken piston rings and bent valves can be easily manufactured by an engine close to TDC being forced over the top. Jim
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
