Posted by robgIN on February 22, 2013 at 19:13:29 from (76.208.15.53):
In Reply to: F20 water in oil posted by Daninsc on February 22, 2013 at 15:53:28:
If you are getting water in the oil in an F-20 about the only place it can be coming from is past the sleeve o-ring.Could be a cracked block but most likely o-ring. Did you have the sleeves out ? Any water from head gasket or cracked head is unlikely to get in the oil, unless you get a lot in the cylinder and some trickles past the rings.As said before, just take the inspection covers off and look around the bottoms of the sleeves with a mirror and you will probably find the leak.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
