Re: Oil in coolent of Farmall Cub
Posted by GaryM on November 08, 2000 at 18:18:31 from (63.49.12.214):
In Reply to: Oil in coolent of Farmall Cub posted by Curt on November 07, 2000 at 17:09:47:
Curt, I just experienced the same with a super-c, had to remove the cyl. head and have resurfaced, head had warped where oil travels through the cyl head to the rocker arm shaft, be sure to flush radiator and block afterwards. Hate to be bearer of bad news but hope this helps. Oil pressure 20-30 lbs. overides rad. pressure of 5-10 lbs.
Good Luck
Post A Followup
: Re: Re: Oil in coolent of Farmall Cub
