Re: 706 steering wheel kicking my butt!
Posted by Janicholson on February 23, 2013 at 14:20:05 from (74.60.94.18):
In Reply to: 706 steering wheel kicking my butt! posted by Farmall-h on February 22, 2013 at 18:27:51:
If you are reusing the wheel the only advice I can give is to pull up on the rim with at least 100 pounds of force where the spokes attach, then use a sharp 1/2" cold chisel, place the chisel radially out from the shaft and strike it firmly, not radically. Move 60 degrees and do it again. Repeat all around, then do it again all around in the same grooves. This expands the diameter of the hub evenly and also shocks the splines. Jim
