436 issue
Posted by timis on February 23, 2013 at 15:22:20 from (108.161.57.60):
Got my 1586 out -- we"re going to go thru it before spring. Its going to be a second tractor this year - but still see some hours. Antifreeze was a little low. I was going to set valves and noticed a bit of antifreeze in the oil by the rocker arms. However I cannot find anything in the bottom end of the engine. I have good oil pressure and dipstick is actually below full. The last time I used this tractor it had its hands full with a chisel -- so I"d think if there was antifreeze in the oil I"d have cooked the bearings. Possible injector sleve leaking or oil cooler - When I had my 7000 lose o-rings it dumped into the oil pretty quick and if you pulled the stick itd be over full. It does have alot of blowby. Any help would be appreciated.
