As MIster T said the loader hooks up just the same but since I didn't have the IH spacers I used some spare drawbar bracket parts from an H parts tractor. The box steel pieces already had the correct bolt holes drilled through them and the angle iron pieces were bent on this drawbar so I had not been able to sell the drawbar brackets whole. I just had to go to the hardware store and get some 5/8x10" bolts and everything was fine. At first I got galvanized carriage bolts but I could only get the nuts onto them if I used grease and a lot of force and I could not get them all the way tight. After that I found some regular grade 5 hex head bolts that worked a lot better, but I still have to replace the carriage bolts on one side. Zach
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
