Re: tractor implement
Posted by Handyman on March 12, 2009 at 20:06:00 from (63.239.240.97):
In Reply to: tractor implement posted by Tony_Idaho on March 12, 2009 at 08:02:01:
that roller is a tire roller, its just a bunch of truck tires stacked together over a steel pipe with a plate steel flange welded to each end to keep the tires on, then a shaft is put through the center for an axle,pillow block bearings are mounted at each end and a frame is built to make a towbar for it. usually they are run dry but could be made to fill pipe with water if wanted. I have seen them anywhere from 6 feet wide to 24 feet wide.
