Posted by Haas on February 24, 2013 at 16:20:39 from (50.142.111.41):
Here is the update on the wiring for the late model IH-140 with factory alternator. I hand sketched this up and then scanned it, so I hope it can be read. This shows the head lights, turn signal, flasher, tail light and work light connections for IH 140 tractors SN 62472 and up as I figured it out on my tractor. This is 140 tractors with the Factory alternator. I changed the terminal connections from the way I found them because on the light switch terminals B and E are connected when the switch is in the off position. This means that in the original hookup I found that a separate switch would be needed to turn off the work light, so that the off was not really off. So I changed the power in from terminal E to A and the headlights from A to E. Also the new switch I got Terminal D and F are connected in positions 2, 3 and 4 on the switch which means there is not a position except off on the switch where the flashers are not on. So I added a toggle switch so that the flashers could be turned off when other lights are on if desired. HOpe this helps some folks.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
