Re: finishing up 10-20
Posted by rustred on February 24, 2013 at 19:11:57 from (72.172.100.113):
In Reply to: Re: finishing up 10-20 posted by wilson ind on February 24, 2013 at 15:18:54:
ur not even close. those tractors never ever had triple rib front tires in the 1920's or that rear design. and that tractor was originaly on steel .
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
