Fast hitch to break tire beads
Posted by Zachary Hoyt on February 26, 2013 at 10:05:10 from (50.122.171.71):
I had to get a 15.5/38 6 ply tire off a rim and I tried it first with the Massey 35 using the loader but even with the front end off the ground it was not heavy enough to collapse the tire. I put it under the fast hitch drawbar and it pushed it right down so all I had to do was use the sledgehammer a little bit and it popped right off. I always used to have to push it down in at least two places with the loader before it would pop off the rim. The down pressure is not strong enough to lift one tire off the ground as is shown in the manual but I assume that is because the tires are loaded and therefore too heavy.
Zach
