Re: ihc two row rubber tired pto corn binder
Posted by 440 six pack on February 26, 2013 at 13:55:05 from (24.111.10.187):
In Reply to: ihc two row rubber tired pto corn binder posted by zanslastclu on February 25, 2013 at 17:22:15:
There is a 2 row binder at the Menno Power show in Menno SD that gets used every fall.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
