Re: Farmall SC bleeding green
Posted by The Red on February 26, 2013 at 14:30:47 from (69.246.205.0):
In Reply to: Farmall SC bleeding green posted by Cjet on February 26, 2013 at 13:28:13:
You are very fortunate your Dad didn't replace that rubber gasket at the bottom of the oil filter can. That could have ruined the bearings. Drain both the coolant and the oil, pull the head and let us know. I had a 1942 Farmall H that had coolant in the oil. I pulled the head and then the pistons and sleeves. #1 cylinder had a hole in the side from a broken connecting rod somewhere in it's lifetime. Ended parting that one out.
