Re: MD power steering advice needed
Posted by Hugh McKinney on February 26, 2013 at 15:08:36 from (75.104.206.93):
In Reply to: Re: MD power steering advice needed posted by IKEin NC on February 26, 2013 at 12:42:37:
It moves about ten to twelve degrees, or about one tooth"s worth on the gear on the hydraulic pump. And no, you don"t have to remove the front cover. Don"t make something hard out of it, if you are off by a tooth, just take it off and move it, enjoy the challenge, the reward is worth it when it fires up and you"ve got it timed, and it"s got power steering!
