H Governor Throttle Linkage
Posted by Doug Kieta on February 26, 2013 at 18:26:30 from (71.54.113.177):
Today I rebuilt the carb on my H. After I reassembled it on the manifold, the tractor started easily, but the throttle would not change engine speed. When I inserted the governor rod tang into the carb throttle shaft bushing, the slot for the tang was positioned at about 9 o-clock when looking into the carb. I am thinking that the orientation of the tang is incorrect. Can you give me some advice how to correct this problem?
