Your '49 M has a gear shift lever that is tapered at the top to accomodate the rubber shift knob. Because of the taper, it will be nearly impossible to cut the necessary threads. Only solution would be to cut off a portion of the lever and then weld a short length of 1/2"x20 to it.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
