Posted by rustcollector on February 27, 2013 at 09:11:12 from (70.195.194.0):
In Reply to: final drives posted by Ontariojohn on February 26, 2013 at 12:17:26:
Did the transmission gear shift get moved to an "In Gear" position during the work? Did you have the transmission cover off? Turning the axle flange will be much harder than with a wheel on the axle? If you can feel gear backlash by turning the axle flange, it is probably in the bull/pinion gears. Not knowing how you went about putting the seals in leaves out details that may point to your problem.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
