Re: painting 06 emblems
Posted by Jeff311 on February 27, 2013 at 15:49:16 from (50.90.51.62):
In Reply to: painting 06 emblems posted by Kirk Affeldt on February 26, 2013 at 19:52:12:
The "gold" on the original 404, 504, 606, 706, 806 and early 656 emblems was an anodized coating that wore off fairly quickly when exposed to sunlight and weather. Under the anodizing is the aluminum emblem. The 1206 emblems did not fade out as quickly away from the gold due to a thicker anodizing layer that was applied when they were made.
