Re: farmall A oil bath filter
Posted by Lyle on November 09, 2000 at 13:18:11 from (199.224.92.167):
In Reply to: farmall A oil bath filter posted by Peter C on November 08, 2000 at 10:58:05:
Peter, my manual calls for the oil cup on the air cleaner be cleaned every 10 hours of operation, and refilled with 3/4 pint of new clean oil, the same viscosity as you use in the engine.This I should think would be 30wt. They also recommend that the entire unit be taken off the tractor and cleaned every 60 hrs. This would be if the tractor was operated in very dusty conditions. Good Luck
Post A Followup
: Re: Re: farmall A oil bath filter
