Re: Best Source for trans/rear axle bearings/seals ?(Super M
Posted by Old-F20 on February 28, 2013 at 07:24:00 from (71.7.101.5):
In Reply to: Best Source for trans/rear axle bearings/seals ?(Super M) posted by mike1972chev on February 28, 2013 at 07:18:36:
what was explained to me were that original inners were a ball bearing type. the heavy duty version of that was a 'roller' bearing meaning is has the barrel shaped rollers instead of balls. they can handle a larger load on the face of them.
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
