Re: Farmall SC bleeding green
Posted by Bill in NJ on February 28, 2013 at 08:36:26 from (165.247.0.226):
In Reply to: Farmall SC bleeding green posted by Cjet on February 26, 2013 at 13:28:13:
Here's my suggestion. First I would loosen the engine oil drain plug at the bottom of the oil pan. If any anti- freeze comes out stop and pull the engine apart. It's got an internal leak that could be disasterous if you run the engine for any amount of time. If oil only comes out tighten the plug. Then I would clean the engine with gunk or some other good engine cleaner. Let it dry, start the engine and watch for seepage. It should be obviuos where the leak is when there is no grease and dirt to confuse the issue.
