Re: ? remove rod that goes through clutch+brake pedal?
Posted by pete 23 on February 28, 2013 at 10:18:58 from (74.47.40.242):
In Reply to: ? remove rod that goes through clutch+brake pedal? posted by Aaron909090 on February 28, 2013 at 09:26:35:
Problem, there is a notch in the shaft to clear the ring gear on differential. You cannot get the shaft out without moving the differential.
